I want to install a backyard pullup bar similar to this one. It's essentially 2 pressure treated wooden posts connected with a metal bar and anchored into the ground with concrete.
I'm about 180lbs and primarily do weighted pullups. Sometimes I use over 100lbs of extra weight so it should be able to handle about 300lbs comfortably. Would 4x6 posts be sufficient or would it be wiser to use 6x6 posts? The 6x6s seem to be a lot more costly so I'd prefer to go with the 4x6s if they're a reasonable choice for me.
Anything else I should keep in mind? The author dug the holes 2ft deep but I'm planning to make them 3ft deep as that seems like it would add more stability.
Location is in Western Washington state, near Seattle. According to this article the frost depth is about 10" unless I'm misunderstanding.
Thanks
