I have:
DCS RGU 366-N oven
Symptom:
When I try to start oven, the ring lights will light up, but gas never flows, and ignition never starts.
Checked:
- The stove burners work.
- I hear the relais click when I switch on oven and temperature knob.
- Stalled Fan Thermostat (SFT) is closed (0 Ohm), as expected.
- High Temp Cutoff (HCT) is closed (0 Ohm), as expected.
History:
The last time the oven malfunctioned, it was caused by a burnt out Stalled Fan Thermostat (Oven ran with door ajar.) That thermostat is mounted near the control knobs on the front. I successfully replaced it, and the oven ran fine for 7 months after that. This time, the symptoms differ: ring lights do light up now.
Schematic:
This schematic was glued on the back of the unit. Kudos to DCS to ship the stove with schematic attached.
Initial diagnosis:
I thought originally that this time, the HTC (High Temp Cut-off) switch is broken. But the HTC measures 0 Ohm. Also the SFT measures 0 Ohm. Those seem to be fine.
This is the view when I removed one back-panel:
Current diagnosis:
Considering that all the switches close, I think it is valve-related. The unit has a safety valve that wont open as long as the igniter does not have the full 3Amp current flowing through it.
My symptoms are consistent with a defective igniter. The only unexpected part is that neither BAKE nor BROIL works, so that would mean two defective igniters? Which is kinda weird.
Plan:
I have removed the bottom igniter, and will attempt a replacement. The valve mentions I need 3.3/3.6 Amp 60Hz. This is the removed igniter:
Question:
Why will the oven not turn on? No gas, no ignition. Whereas the stove burners will work just fine.
