Literally all I know about these windows is the following sticker, apparently designed to peel off before the warranty expires:
NAMI window sticker
How can I identify the maker for warranty purposes?
I know that NAMI is the certifying organization not the vendor https://diy.stackexchange.com/a/27900/5960 I've tried entering NAMI-310414 number into NAMI's database https://www.namicertification.com/supplier-directory/ without luck.
The codes can be checked against NAMI's insulated window manufacturer directory, which is searchable on the organization's website.
National Accreditation and Management Institute (NAMI)
On their webpage under Q&A tab:
Looking for a Code The certification label or mark bears a code that allows traceability of the product. If you cannot find the code on our web-site, please contact NAMI at (804) 684-5124 or nami@namiinc.com. NAMI will direct you to the manufacturer of the product.
    In light of the OP's edit (seems to have been made after your answer was given), can you offer a recommendation on which codes should be entered on the site to get him the info he's after? Maybe even a direct link based on the appropriate code?
    Sep 13, 2021 at 12:05
  • Doesn't answer the question (to the OPs satisfaction, I'm sure), but most certainly tells him how to get the info. +1
    Sep 13, 2021 at 14:30
  • @FreeMan Both of us (me and OP) are guilty of laziness - make a phone call. :) Actually, I prefer to leave the answer as was, so it fits the interest of more readers rather than a single person.
    – r13
    Sep 13, 2021 at 14:43
  • On the bright side, if someone else can't find it on the NAMI site with the numbers they can identify, at least the phone number/email are listed here for convenience. Covers most/all possibilities.
    Sep 13, 2021 at 14:59
    From the OP : Turns out it's Ply Gem Windows -- who makes a sticker that falls off easily that does not have their name on it. Himm. Things that make you wonder....
    – Bryce
    Sep 15, 2021 at 20:13
