I recently got water damage from an hvac unit flood and it went under our laminate hardwood floors warping them. As a result I have to remove a lot of the boards in order to access the damaged area. There are a few boards like the one in the pictures where the boards were cut around the shape of the door jambs and then slid under the casings. The thing is I'm not sure how they got them in there based on the ordering and I don't know how to get it out without cutting the board or removing the door casings. I'd love some suggestions or tips on how to get them out.
Edit 1: I changed the picture so you can see that situation a bit better. I double checked and the board is cut out around the jamb as indicated by the dots in the image. The solid lines show where the board ends. The arrow shows which way the board needs to be lifted in order to remove it from surrounding boards. As you can see the board can't be slid out to the left because of the cut around the jamb. It also can't be lifted to separate it from the board it's connected to in the next row because the gap between the board and the casing is so tiny. I'm not even sure how they got it in there in the first place.
