I have a GE front-load washer (wcvh6800j1ww) with a dryer mounted on top. I need to change the door seal, and the default instructions (linked below) involve removing the top and control panel in order to access two screws on the door panel. The washer and dryer are stacked in a location that makes it extremely difficult to unstack, specifically, disconnecting and reconnecting the dryer vent without causing damage to drywall and flooring.
If you watch the below video, it looks like the two screws in the top corners of the door panel are the only reason you need to remove the control panel and top. I'm wondering, would it be possible to drill two small access holes in the panel that covers them, so that I can get to those screws? Or does it look like it the door panel needs to be lifted in a way that the control panel needs to be removed either way?
https://youtu.be/7J3RqONy4pw?t=138
Aesthetically I'm not too concerned about the holes since I could easily plug them with screw hole covers painted to match the enamel, but obviously I don't want to do it unless I'm pretty confident it will work.
