21
Got this at a yard sale in a bin with mostly random fasteners. Its about 3" long.
It has a tip like a nail but a dipped-looking rubberized coating.
Any ideas what this could be for? Someone suggested a small awl but given the very small size of the "grip" (if that's what it is) that seems unlikely.
In the USA if that makes any difference.
    why do you need to know this? ... some tools are useful for other than intended purposes
    – jsotola
    Sep 5 '21 at 18:49
  • 6
    @jsotola mainly just for learning purposes / curiosity. I've done tons of DIY on my house in all areas, so I don't come across tools totally new to me very often. Sep 5 '21 at 18:50
  • What is the diameter of the metal rod? It kind of looks like the tool you use to remove plastic sprinkler pipes that have been snapped off at the fitting, but the diameter looks too small.
    – longneck
    Sep 5 '21 at 19:38
    @longneck I have not measured, but it is very similar to a standard framing nail, if not slightly less. Sep 6 '21 at 0:43
  • Eye pick, maybe?
    – Vikki
    Sep 6 '21 at 18:31
37
From the Harbor Freight Hook Assortment (item #67587), it's a straight line "hanging hook." Photo below from the above mentioned web site:
storage hook assortment
  • 7
    @StayOnTarget actually it is quite clear now ... it is a padded nail for hanging things
    – jsotola
    Sep 6 '21 at 2:04
  • 7
    the ladder shapes in the image are created when the plastic is heated and compressed, sealing closed the top and bottom finger slicing plastic.
    – fred_dot_u
    Sep 6 '21 at 9:32
  • 4
    @criggie those are sonic welds in the package creating bonds between front and back of the package. Yours for easier package opening, not! Without them, the plastic would de-form and all the pieces would be found in a big lump at the bottom. Sep 6 '21 at 17:05
    @Conrado you gently walk the Plasti-Dip off it, then drive it, then file down where you mushroomed it, then wet the Plasti-Dip and slide it back on. Sep 6 '21 at 17:11
    You hammer it in at an angle and then you can hang things on it.
    – Valorum
    Sep 7 '21 at 19:01
9
It's a scriber used for marking wood, metal, etc. for cutting or drilling.
Small pegs you can hammer into a board where you can hang things on, like a towel or your size 10 wrench
Hardened point - then a tile cutter.
    You mean like, to score it? Why such a miniscule handle? Or is it meant to be mounted in something? Sep 5 '21 at 18:29
  • @StayOnTarget bigger is not always better.
    – Solar Mike
    Sep 5 '21 at 18:31
  • I can't argue with that in general. I guess this would be like holding a short pencil. Sep 5 '21 at 18:31
-1
That looks like a hand drill / hole maker. It is a type of awl (or, it could also be a bodkin for leatherworking or be a two-in-one as both) - thanks @StayOnTarget
It is used to facilitate screwing in things with your hands. (hooks, curtain hangers, etc). These are fairly easy to screw in, but it can be a lot of work to get the screw to engage. Punch or twist a rough hole with the tool first and then engage the screw.
