My Maytag Bravos XL washer stops in its spin cycle and won't continue. I unplugged the power and looked in. Lot of un-drained water and clothes. I tried to start it in Rinse Spin cycle but won't. Gives DRN error code.
How do I simply drain the water out--- not manually of course.
    It would help if you can include what error code it's giving you. Sep 1, 2021 at 20:37
  • Does the manual give a button sequence to force a drain? Most do.
    – Solar Mike
    Sep 1, 2021 at 20:40
    Just checked the manual. -- There are 5 things to check under the Won't Drain section. Sep 1, 2021 at 20:45
  • This not automatic but most washers will drain if the drain hose is below the level of the tub. You can try draining that way into a bucket, pan, or something convenient.
    – Gil
    Sep 2, 2021 at 15:16
