My house has 2 main connections (240v). It has 2 meters for each connection. It's a multi-wire (shared neutral) setup, I think. The house used to be two houses joined into one, with 4 circuit breakers (2 per side )
Inside the house all the outlets work, but I noticed the lights getting dim or bright on both sides of the house, and things like my coffee grinder operating at what seemed like only 10% power.
I had an electrician come by and he measured the voltage coming in from the pole on the roof (before the meter) and on one side it was 80v and on the other 150v. He said it was a problem with the transformer or the neutral line out to the pole, and to call the power company. Problem is where I live it's easier to move houses than to get the power company to show up. He also didn't test any of the receptacles in the house or test lines from and out of the circuit breakers.
One thing I'm thinking is that the neutral has some corrosion somewhere (possibly at the meter connection) or is just not attached correctly at the ends? Would this cause the behavior I'm describing?
Is it possible that one of the outlets is causing this problem across both houses?
Here are some photos of this disaster:
Main to house
Crazy split
Left side neutral
Right side neutral
