I am trying to calculate what trowel size (fast set thickness) I need in order to obtain a flush level between the tiles and the green marked area in the diagram below. Here is some context first:
I am not planning to tile to the ceiling as I have uneven ceiling and I think it will look too oppressive to have tiles all the way up the to ceiling
For that reason I decided to go with 3 horizontal rows of tiles, starting at ~2" above the floor level. The first two inches between the tiles and the floor will be covered by a plinth (same tile as the wall tiles or like the floor tiles) and the shower base
The specs of the tiles I am using are here
https://www.anatoliatile.com/content/uploads/Prima_Porcelain_Tile_screen.pdf
White Matte Rectified 24"x24"
So I am trying to determine if using a 1/4" trowel will get me flush with a layer of drywall over cement board (or maybe two layers of cement board) above the tiles (marked with green on the picture) -two layers of cement board = 1" -one layer of cement board + 3/8" the tile =7/8"
this means I have 1/8" thickness for the thinset and two times that, 1/4" for the trowel size Is my calculation correct ?
I am not sure if 1/8" thinset is enough for that size of the tiles (24"x24")
The glass panels will be 72" high (not sure if it will look nice to have the glass panels higher than the top line of the tiles)
I still have to determine the positions of the verticals (where to cut the tiles on the vertical) and how I place the tiles there, to look esthetically pleasing.
