I am finishing the basement in my 1926 house and planning to frame a proper wall against the concrete foundation - studs, insulation, moisture barrier, etc.
The previous owners had painted over the concrete foundation, and I noticed a fair bit of efflorescence coming through the paint, so before I framed I planned to scrape off the efflorescence where I saw it, treat it with a cleaner for efflorescence, paint it over with dry lock, and then do my framing.
As I scraped it, chunks of the wall peeled off fairly easily - I can't tell if it was just a thin layer of drywall or concrete backerboard, or actual concrete / plaster bonded to the paint (you can see it in the photo). The discoloration in the wall and removed chunks worried me a little, as well as the fact that some of the darker chunks that you can see in the photo were pretty soft, almost like wet cement / dirt, so I'm wondering if I need to do more than just what I mentioned above. Should I be scraping clear the whole wall? Is additional masonry work needed first? Any advice would be helpful.
basement wall
    You should first identify the type of wall. Is it concrete, masonry, or concrete block? The weathered material can be plaster too.
    – r13
    Aug 29 at 0:29
    You should very much have that paint tested for lead before scraping/scrubbing more of it off.
    – Ron Beyer
    Aug 29 at 1:25
    re @RonBeyer comment - you can get a cheap lead test kit at a paint store and test it yourself.
    – Willk
    Aug 29 at 15:18
