The shower handle has the shaft exposed. I want to cover it but I don't want to put the circular plate that Moen (mainly) sells. I don't want it cover the tiles. Just the shaft. Is there something available for this or should I do something custom?
You just want the shaft covered so it matches the faucet? Would imagine someone has a chrome tube like piece that would fit the shaft.– crip659Aug 28, 2021 at 19:51
Yes, just the shaft. Chrome tube ? Interesting. Where could I find this ?– LouAug 28, 2021 at 20:26
Would try plumbing shop first, maybe automotive shop second(piece of chrome exhaust pipe). Need to have the outside diameter of shaft and length. Does handle just turn or is there a pivot to it also(tip of handle moves towards wall)? Will make length harder to measure right.– crip659Aug 28, 2021 at 20:46
Could you have mounted it deeper so just the handle was on the surface?– Solar MikeAug 28, 2021 at 21:39
@crip659 Handle rotates and moves from the wall to the floor.– LouAug 30, 2021 at 14:16
Show 3 more comments
