The attached picture below is my wall after I paint stripped it: I would apply the paint stripper on the surface, let it act for the required amount of time and then I would scrape - I've repeated this 3 times on the same wall to achieve the result as in the picture.
I have a few questions please :
Visually, is the wall clean enough now paint-wise for me to continue to the next step or do I need to reapply the stripper again and give it more scraping?
Before I repaint the wall, what are the advised steps I should do to prep the wall before I can paint on it? I assume I would need to do something to make sure the paint stripper chemicals are off the wall like sanding or cleaning with water or spirits?
Many thanks!
