We recently moved into a mobile home and one of the doors would keep opening.
I adjusted the box and strike plate (just moved them all the way over, shifted it over to the right to be closer to the outside of the door) which solved the problem for a while:
Strike in door frame with screws
But then it started coming open again and I saw the box shifted left again.
So I moved it back and re-tightened the screw, this time using a power tool, but it came loose again.
The door opens outwards (to the right in the picture) and I wonder if the box/strike-plate are mounted upside down... I can't take them out through the hole though.
Do I have to take the door frame out to flip the box/strike-plate upside down? I just want it to stop shifting left so the door closes properly and stays closed.
Update:
I tried flipping the strike without removing the door frame as @harper-reinstate-monica suggested. It's pretty tight in there, the right side doesn't drop into the door frame.
Strike with string
Here is a picture of the door frame as @crip659 suggested:
Door frame
    I'm pretty sure that plate will come out through the hole. It's a bit like one of those Chinese puzzles where you have to get it oriented just right. Looks like if you remove both screws, slide it all the way left and then tip the right side into the opening you can move it up or down and pull it out. I'd tie a string onto it in case it slips out of your fingers though.
    – jwh20
    Aug 26, 2021 at 16:03
    "The door opens outwards" & "I wonder if the box/strike-plate are mounted upside down" - it looks like it: the little ramp (by the "PHILIPS IND." text) should aid the smooth closing of the door. "I can't take them out through the hole though" - I don't have an answer for that. Aug 26, 2021 at 17:15
  • 5
    the strike plate looks reversed ... the rolled lip on left side in preventing it from laying flat and tightening up ... that is why it keeps sliding
    – jsotola
    Aug 26, 2021 at 18:32
  • Think you might have to take the whole side off. Be nice if you can post a picture or two of the whole side frame. The strike plate seems to only fit from the inside of frame.
    Aug 26, 2021 at 18:55
4 Answers 4
Those little screws are never going to resist the door forces. Not ever. Not even with Loctite,
The strike is upside down
Look carefully. See the rectangular hole. See the vertical centerline of that hole. Now see the line between the screws. The rectangular hole is NOT on the screw centerline, it is offset slightly left (toward the ramp).
Flipping it over will cause the rectangle to be offset slightly right of the screws. Exactly where you're trying to position it.
How to flip it over, though
The people who designed this door were not morons. The strike is designed to be removable through that hole.
Loosen the screws and tie a string to the strike so you don't lose it.
Remove the screws altogether and slide the strike to the left, until the right edge drops into the hole. Let the rest of it tip in also. Then, when it's all in the hole, let it drop down enough to get the top of the strike to come out the hole.
If the builders were nice, they made that space of limited depth so it can't fall too far out of reach. But don't count on it until you know that for sure.
  • I've edited my question to add a photo of my attempt to remove the strike. I would love to solve this without having to take the door frame off! Aug 28, 2021 at 13:26
  • Remove one screw.
  • Loosen the other screw.
  • Add a drop of thread locker to the removed screw and install.
  • Remove the other screw.
  • Add a drop of thread locker to it and install.
  • Tighten both screws very snugly* with the strike plate in the proper location.
Generally speaking there are 2 grades of thread locker compound. One is removable (taking quite a bit of extra torque to break it loose), and one is not removable (without applying high heat). I'd suggest the removable kind.
If it still slips after thread locker is applied, you may need to go to epoxy.
  • Wait for a day when the weather is within the working range of the epoxy you've chosen.
    • Make sure you choose one that says it's good for metal (most are).
  • Mix up some epoxy.
  • Follow the directions above for the thread locker, but replace "thread locker" with "epoxy".
  • Once both screws are in place, squeeze some extra epoxy in behind the screws and into the gaps between the strike plate and the door itself.
  • Gently close the door to check, one more time, that the strike plate is in the right location.
    • You don't want to make a permanent fix only to discover it's permanently in the wrong place!
  • Prop the door open until the cure time of the epoxy has expired.
    • You don't want a stray bit of epoxy sticking the door closed.
    • You also don't want it opening & closing and potentially moving the plate out of the proper location.
* You want to ensure that you don't get them so tight that you strip out the threads, of course.
Looks like the screws thread into female-threaded holes in the strike plate. It also looks possibly like there is some wood back there visible through the strike plate. It's hard to tell what the threads of the screw are actually biting into. It's possible if you used a power tool, the substrate may have been stripped, or the screws are stripped. A couple solutions you could try, but just going in blind here without knowing more about the hardware.
  • Take the screws to a hardware store, find screws with a slightly wider and longer shank, but of the same type, screw those in, it should hold better.
  • take the screws out, see if they were locking into that wood piece at the back, and make sure they are not stripped. Jam a bunch of toothpicks into the hole. Even better if you have some wood glue to coat the toothpicks with. re-use the screws, and they should bite better.
Do not use a power tool. This is likely too much torque for the application.
Those appear to be sheet metal screws: they cut their own thread into the tabs of that box. The thread of a sheet metal screw is quite coarse and doesn't lend itself to being tightened (and staying that way) especially when vibration or impact are involved. (photos below are from www.globalindustrial.com)
sheet metal screw
I'd replace the screws, first one and then the other, with a machine screw and lock nut. Pictured below is a nylon lock nut; other kinds are also available.
machine screw nylon insert lock nut
Tightening the screw and lock nut will be challenging on account of the limited access to the rear side where the nut will go. An impact driver can help: hold the nut as well as you can with a straight or curved needle nose plier, then give short bursts with the impact driver. The nut will spin, but hopefully the first few impacts from the driver will tighten the nut a little before the spinning begins.
As an alternative, use a regular nut with thread locker compound. It'll be easier to tighten and probably would hold as well as the nylon lock nut does.
