I'm looking for a replacement for the pictured 1950s internal door catch. I can't find one, and don't know what they're called. I've tried "gravity catch" and "teardrop catch" but those are not the same thing. Reverse image search isn't helping either.
Any ideas?
  • Might look nice, but I have a feeling that they might be not allowed now since a person inside could not open the door easily.
    Aug 26 at 9:51
  • Cast a new one is an option.
    – Solar Mike
    Aug 26 at 10:00
That is an antique cabinet door latch called a Hoosier Cabinet Latch. If you want a similar latch you could contact the House of Antiques Hardware at 888-223-2545 or at Van Dyke's Restorers, 1-800-237-8833 This is what I found when I Googled antique cabinet door latch. hope this helps.
  • Don't think the OP will be visiting House of Antiques in person...
    – Solar Mike
    Aug 26 at 12:58
So another option instead of casting a new one is to cut that worn part off, then drill and tap it to receive a new threaded bit cut to length.
Should work well.
  • Good idea, unfortunately the one I want to replace is broken beyond any repair (I posted that photo so you could see what it looks like)
    – aucuparia
    Aug 30 at 5:38
  • @aucuparia Answers are based on the evidence provided, can’t do more than that.
    – Solar Mike
    Aug 30 at 5:56
