I have this small angle grinder and I want to use it for beveling tiles that I am going to install.
The process also requires some polishing of the bigger than 45 degrees cuts and they use a polishing tool like below. That looks like an angle grinder with some adapter installed. What is the name for it?
  • Looks like a sanding disk for peel and stick sanding disks. The guard is just removed for the picture, right?
    Aug 24, 2021 at 15:29
  • or it could be a scotchbrite pad on there,
    – Jasen
    Aug 25, 2021 at 2:02
  • Note that I've only ever seen these sold from Chinese or other "off shore" sellers. Its not something you can buy at the hardware store - I think there must be some safety regulations that keep others from selling them.
    – JPhi1618
    Aug 25, 2021 at 19:22
Product search terms:
Angle grinders have a threaded output shaft, so the one in your photo probably just screws on.
