PVC pipes can be joined using couplers and glue to form a durable water tight connection. I have not had any such luck with corrugated pipes - and have had to deal with the consequences of leaking pipes pieced together by landscaping contractors.
The latest I have heard is that they are coupled by rotating the second section into the first. That is just not at all reassuring since that approach has failed repeatedly. I'm not comfortable with purely "mechanical" solutions : but cement/glue does not seem to be a thing for corrugated pipe? What are the options here?
Update I am dealing with a number of pipes like this already buried and/or already leading down off the property. I can not readily just change to another method of drainage. It is a matter of getting the best result with exactly this type of corrugated pipe. For future I will take these difficulties into account when I actually have the chance to be in control of the decision .
    True - i'll update the photo Aug 14, 2021 at 3:25
    Rotating one inside the other only works if the corrugation is like a thread. For the pipe you show thr ridges are parallel which won’t act like a thread.
    – Solar Mike
    Aug 14, 2021 at 7:21
  • i've used shoe goo to join similar piping. coat the inside "female", twist the male after inserting. worked for draining a pool with a siphon. – dandavis 22 mins ago
    – dandavis
    Aug 14, 2021 at 16:50
  • @dandavis I have not been able to get an insert to work even after cutting a section with a box knife. It is difficult to constrict and hurts my wrists even to get a couple of sections. It looks like i'll need a real coupler - which I've also tried without success so far. Aug 14, 2021 at 17:35
  • you might try heating up the female half with a torch or hot air gun. While hot, you can stick two boards in the end and spread them apart to (slightly) stretch the pipe and make it easier for the snake to swallow its tail.
    – dandavis
    Aug 15, 2021 at 13:30
Corrugated drain pipes don't do waterproof joins, or particularly secure ones. You're supposed to bury it and then the dirt holds everything in place, and keeps most of the water inside
So they're are no good if there is any head of pressure that comes above the surface of the ground. because you'll get an undesired water feature (like a pond or a fountain) at the join.
If you need to handle water under slight pressure you'll need to use a different type of pipe, eg: PVC.
9
  • Thanks. I have updated the question with detail that these are pre-exsiting pipes and I am not in a position to change these out unless getting a backhoe to dig them out. Aug 14, 2021 at 17:18
  • either you have too much water going into the pipes or they are partially blocked.
    – Jasen
    Aug 14, 2021 at 21:43
  • Not either one. I'm trying to provide tight join of sections of existing corrugated pipe. We had work done on foundation piers and they have been severed as part of that process. Just need to zip them back up well. In other cases there is a steeply sloped section in which I added extension: need to make that tight as well. Aug 14, 2021 at 21:58
  • Just push them back together then, and bury them.
    – Jasen
    Aug 14, 2021 at 22:01
  • critical not to have leaks - that won't fly . Wow this is hard to achieve Aug 14, 2021 at 22:23
If you are going to use drainage pipe that will buried more than 12" or have any weight on it, you should not use that corrugated piping. I used it for drainage in depths between 2 and 5 feet and it crushed reducing the flow rate. I had to replace it with sch35 drainage pipe.(It cost a lot more to do it right).
The pipe you show is used by many contractors and home owners for all the wrong reasons; it is cheap and light and can be handled by one person and NO, the joints will not be water tight.
My 2 cents.
  • This is helpful for those in the planning stages. I already have tens of meters of buried pipe so am looking for how to handle these in the current state. Aug 14, 2021 at 17:19
After multiple trial and errors the following did result in a water-tight seal:
  • place rubber-tape / water proof tape inside a coupler on the downward end
  • place rubber-tape / water proof tape around the entire outside of the coupler
  • layers of gorilla tape or similar high strength water-resistant tape on top of and around the rubber/waterproof tape
In addition ensure the proper leveling of the pipes. I had to do some more digging to correct a section of pipe that had a positive slope.
