I have a tap dripping hot water and need to turn off the supply of hot water. The house has a gas water heater in the basement. There is a valve on the water supply leading into the tank and another valve on the hot pipe coming out of the tank. To work on my dripping hot tap, is it better to turn off the water going into the tank, the water coming out, or both?
Thanks
