Currently I have 4 small low voltage transformers connected to 4 circuits of low voltage yard lights. They are under my deck, and I turn then on and off using switches above the deck.
I want to consolidate those transformers into one transformer.
https://www.voltlighting.com/clamp-connect-300-watt-12v-15v-multi-tap-low-voltage-transformer
My question is how do I use these switches to turn lights on and off from the deck.
I would like to use the same switches from the old transformers to do this.
It would be impractical to have to crawl under the deck to turn the lights on and off.
Should I connect the low voltage light wires to the switches, and then run wire from the switches to the transformer for each light circuit. I will have to leave the transformer in the ON state all the time.
What is the best way to do this? Any help would be appreciated. Thank you,
