I need to drill into some tile. How can I tell if it's ceramic or porcelain? I want to use the correct drill bit.
  • Welcome. Please take the tour so you know how to participate. "Thanks" comments are discouraged.
    Aug 3, 2021 at 20:11
    I'm not keen to write up a full answer at the moment, but this should help: wikihow.com/…
    Aug 3, 2021 at 20:14
    trick question: porcelain is a ceramic along with stoneware, earthenware, and terra cotta, in descending order of density.
    – dandavis
    Aug 4, 2021 at 3:41
A diamond-tipped bit will drill through either material so just buy it.
Trying to save 50% on a carbide bit for ceramic tile is just not worth the risk of ruining potentially porcelain tile.
  • While good advice, this doesn't answer the question. Just buying it isn't always an option or the wise move.
