I need to buy a new bracket as the one holding the external vent is broken and pipe is wobbling.
What is it called so I can search for a new one? It's about 12cm external diameter.
Bracket
What you're after is a "pipe wall strap".
  • I presume it's one for a Ø110mm/4'' Soil Pipe. My external diameter measurement was 120mm but i believe that inside diameter is what counts for a pipe. So about 5mm on each wall would roughly add up?!? Apologies if this should be new distinct question!
    – k1eran
    Aug 2, 2021 at 21:38
    Yes, straps would usually be sized for nominal pipe diameter, not actual outer diameter.
    Aug 10, 2021 at 12:41
