16
This has been in my garage for a while, but I have no ideas what it is. Anyone out there know?""
50
It is a gear puller. A two and and three arm, use to pull gears/bearings off off shafts/holes. Use the bolts to connect a pair of flats to the centre piece to the arms. The long screw goes in the centre hole, place it against centre of a shaft, the arms go to outside of gear and you turn the screw to remove gear from shaft.
  • Most certainly a gear-pulling set. I have a set that looks almost identical to that.
    – Tonny
    Jul 26 at 10:12
  • 5
    Indeed a gear puller, but often not the best one to use. A "harmonic balancer" type works better in most cases, such as flywheel removal. It uses bolts to make a positive connection. The arms on the type shown above can slip off easily, or even break. However, it does work well for things like removing boat steering wheels.
    – Jason
    Jul 26 at 13:40
    @Jason Quite a few different types. Each type has best design use/size. Type above usually best for accessible gears without drilled/tapped holes.
    Jul 26 at 14:15
  • 4
    @nick012000 Just do an image search for "gear puller" and you'll get thousands of pictures: images.app.goo.gl/H5j4f3mXekcC7mnu5
    – Theodore
    Jul 26 at 17:26
    It's the sort of tool for which you cannot find a good substitute. So if you ever potentially want to pull something off a shaft without twisting or hammering, this is the tool. Can you tell I've needed one and not had one?
    – Criggie
    Jul 27 at 4:40
