I bought a Coast g25 flashlight new 2 years ago. The batteries are dead so I need to replace them. But I can’t unscrew it. It just won’t budge. It’s not rusted, and hasn’t had any other damage that I can see.
First, which end of the flashlight should be unscrewed? I thought it was at the “back” end where the power button is, so I applied WD 40 and tried later and was successful. But the only thing I could see was the power button’s insides. No place for batteries. Should I try to pull this part out and maybe I’ll find the cavity where the batteries go?
The other possibility is the front end where the bulb is. It’s harder to see if there are actually two separate parts screwed together or not. There is a line going around the bulb area, which might be where the parts come together... or it could just be decor. It won’t budge at all. I tried WD 40, but that didn’t help.
Any suggestions? Please tell me where the parts are screwed together so I won’t waste energy trying to unscrew something that’s a single, solid part.
