Every two weeks I have to put hot water down the tub or sink to stop the toilet flushing from making it gurgle. Is it a clog in the line or the vent on the roof? Any suggestions please? Or is it ok to just do this every two weeks? There is no odor. Thank you!
    You have a venting problem. If this has been the case since the beginning it's likely poor plumbing installation. If it's recently started then perhaps your vent has become clogged or blocked.
    – jwh20
    Jul 25, 2021 at 0:14
You might have a grease blockage in the main line to the outside of the home. I would check your cleanout outside and see if you have any grease residue in it.
  • Another possible cause is tree roots invading the main line outdoors. Jul 26, 2021 at 15:39
