I'm trying to remove a Moen kitchen faucet. It is a single-lever faucet with a separate spray hose.
I disconnected all the supply lines and spray hose. But now I'm having trouble removing the faucet body. There is a bracket underneath the sink, and a nut holding the faucet in place. However, even though I loosened the nut, the faucet still won't come off. There is a gap in the threads on the bolt that seems to prevent the bolt from being removed entirely. Hopefully this all makes sense when you see the picture.
