I have a Maytag Bravos XL washer. After a recent power outage it started showing "drn" (drain) error during every cycle except the rinse/spin cycle. The washer stops with the drn code and the only way to get it re-started is to unplug and restart with rinse/spin cycle.
A certified Tech checked it out and said there was no blockage either in the drain pipe or the pump. But after his departure it happened again.
Can anyone suggest a reason for this?
  • "After a recent power outage it started showing". If it was a brown-out then the circuitry could have been damaged; you could need a new control board. Were you not able to replicate the issue while the tech was present?
    – MonkeyZeus
    Jul 15, 2021 at 14:43
  • Thanks @MonkeyZeus. The issue starts after about 35 min into a cycle. The tech did not want to wait and seemed pretty sure that it was solved!
    – DEEM
    Jul 15, 2021 at 15:31
    I hope you didn't pay them already :-/. If you can then get the issue on video and try to get them to come back.
    – MonkeyZeus
    Jul 15, 2021 at 15:39
