The vent tube on my white (latest model?) Insinkerator keeps detaching (blowing off under pressure?) causing leakage inside the cabinet. Is the problem likely to lie in the faucet/tap or the heater itself. Would it be safe to clamp the 1/8" tube to the heater to prevent it detaching itself from the top of the Heater?
There should be no pressure in a vent tube. so it should not blow off.
Find and correct the blockage in the vent path.
