This weekend, I did the big job of sanding down a wood window-frame and then reapplying the wood protector.
It is now raining, and my insecure brain is freaking out that I might not put down a good enough coat.
So what are signs that there is not enough of the wood protector? Or what are signs that show that the coat is enough?
The product enter image description here
The Window enter image description here
    It really depends on the product and the situation. Some will bead well, some won't. You'll know in 20 years.
    Jul 14, 2021 at 15:21
  • yeah that does suck. I would have loved to know before I got mold in my walls.
    – Fredy31
    Jul 14, 2021 at 15:54
    Which wood protector did you use exactly? Every brand is going to have it's own set of instructions so assuming you followed the instructions then I'm not sure what you expect from us. You didn't even provide a picture so that we can provide feedback, you've only shared your neuroticism.
    – MonkeyZeus
    Jul 14, 2021 at 15:59
  • Used Techniseal rona.ca/en/… Instructions are basically 'Give a good coat'. Maybe because I'm a programmer but I kinda hate that its not a hard number lol.
    – Fredy31
    Jul 14, 2021 at 16:06
  • I can't seem to find the manual for your product. Anyways, products like Cabot says "do not overapply" along with "re-apply every 1-3 years" and Olympic says "Apply one thin coat". Set a reminder in your phone to check the wood every 4-6 months. Test it by putting some water drops on the surface; if the drops slide off and do not get absorbed then you're good but if they get absorbed then you need to re-coat.
    – MonkeyZeus
    Jul 14, 2021 at 16:15
That anxiety will always live with you... it's part of mixing DIY "stab in the dark" with techie OCD. (I know.)
Most important with a window frame is making sure that
  • you have a generous drip edge above it,
  • water can flow through/over and not sit or puddle on any horizontal surfaces
  • you seal off all gaps and cracks that might lead to water running down behind the window trim or get trapped
  • you apply the protector to as many surfaces of the wood as possible. If possible in the future, before installation
  • apply the protector on dry wood, that is brushed or sanded clean, so that it soaks in
It's important that wood can dry after it has been exposed to water. That's the first step in preventing rot. Sun and air gaps are friends.
In terms of wear aesthetics, the quality of the product matters, but be prepared to sand and reapply every 5 years (3 - 10 really, depending on product, weather fluctuations, sun exposure, your tolerance)
And to specifically answer the question: if the water rolls off after the protector has dried (24-48hrs) you applied enough.
If the coats feel like a leather layer on top of the wood, it was too much. They can flake off in stead of wear off. The wood will be bare underneath flaked-off patches, whereas wear is more gradual and will provide residual protection within the grain.
The coat(s) should be gripped into the wood and be textured like the wood grain underneath it.
  • Yeah that window is OLD. Like we are wondering if it is original to the house OLD. (We don't have the budget to replace them this year so we are doing the treatment to give us the few years to have the budget to replace. The old one was peeling so we needed to do something about it.) So everything of placement and how its made should be good. But yeah, I'll have to keep an eye on it.
    – Fredy31
    Jul 14, 2021 at 16:30
  • @Fredy31 Yes the peeling parts need the most attention. As long as they are sanded so that only firmly attached patches remain, that's your best bet. Wood protection can last the upper end of the manufacturer's range, when on vertical surfaces with no water run-off dripping over it.
    – P2000
    Jul 14, 2021 at 16:36
  • I busted my ass probably more than I needed to and sanded the whole window, except some small bits where the old did not want to go. Then treated everything. The old treatment was some ugly red matte paint and our new is a tint of brown closer to wood so we cant really just patch the small places where it did peel off.
    – Fredy31
    Jul 14, 2021 at 16:44
    Think I can put my unrest to rest. It stopped raining maybe 30-45 minutes ago and I went to touch the wood. Its dry. Guess its a good sign that the water just slipped off and was not just absorbed into the wood.
    – Fredy31
    Jul 14, 2021 at 16:54
  • @Fredy31 You could add a picture of your work into your question. It would allow people to spot things which you might not be considering.
    – MonkeyZeus
    Jul 15, 2021 at 13:22
