A few days ago, we had a big storm and some of the rain water came through the light fixture of my room. I shut off the electricity straight away, removed the light bulbs and drained the water. It came through the screw holes of the light and didn't get near the wires of my light but it soaked the insulation foil. It's been about 30 hours and the insulation is still damp to the touch but I'm unable to remove anymore via pressing towels to it. How much longer should I wait until putting new light bulbs in and turning back on the electricity to my room? Is there a way to speed up the drying of the insulation? or should I let it air dry the rest of the way? How long will that take?
Edit: I've already located the leak, the vent pipe near my room seal has broken and that's how the water has come in. I'm going to have someone come over and fix it soon, I'm concern about causing a fire in the meantime which is why I asked about the light fixture in the first place. Need to fix the seal to prevent further damage to the light fixture but damage has probably already happen to the light fixture and I might start a fire by doing so...
