I have a WiFi enabled double light switch, randomly some months back one room stopped lighting up.
We have since tried replacing the whole switch which stops everything working and also to use the original but with each set of cables wired to different sides and the same side.
No matter what we do the left switch will only ever light up the left room, even if we swap the cables around.
Some how it will still only light the same room with the original switch and not the other side at all, we even tried wiring both cables into the same side but it would still not light the right side room.
We also swapped out the light bulbs to see if they'd all blown on one side, but that too didn't resolve the matter.
Does anyone have any ideas what the heck could be going on?
