The trim on one of the sidelights around the front door has started to come off (see pictures below). The door gets a lot of sun and I suppose this is what caused this.
I initially thought I could just nail or glue the trim. However if I do that, the trim will not be flush with the others.
- How is the trim attached to the sidelight? Is it glue or something else?
- On the inside side of the sidelight, I see something that looks like nails (see last picture). Is this what holds the inside and outside trim in place?
- How would you repair this?
Thank you!
