I'm running a new light switch and have to unfortunately notch out a hard to access joist to get into the wall above. Our house is a small antique cape house and this will not affect the floor's integrity. What kind of saw would be best for a hard to reach 2x8 board like this?
    The layout is not clear. Using the "edit" button below your question text, and the "moon and mountains" button over the resulting editing window, please attach a photo of the joist you're asking about. Jul 2, 2021 at 1:39
  • Probably an oscillating saw ("Fein", etc), but not sure since the picture didn't upload. Jul 2, 2021 at 2:33
  • It's impossible to say from what little information we have. Photos are necessary.
    Jul 2, 2021 at 15:03
Before you get wrapped up in "notch", have you considered drilling a hole? A long(ish) bit, either auger or spade, will go a good long ways, which makes it easy to deal with tight spaces. And you can pick up a 10-14 inch extension if you need one.
  • I'm now leaning toward a hole with possibly a small hole saw bit. Thank you for the advice, it should also better preserve the joist.
    – Mike L
    Jul 2, 2021 at 3:06
    I can't see a hole saw working well, they are best for thin material.
    – Jasen
    Jul 2, 2021 at 5:20
    @MikeL I would look into a long "electrician's augur" bit. They are available in lengths up to 48" or so, and augur bits have a screw thread at the end that makes them self-feeding after a small push to get them started. They also have a flexible shaft so you can get it in through the hole in the wall, then bend it and push it up into the top plate above. They can be a bit spendy, but your local tool rental place will probably have them for a very reasonable price.
    Jul 2, 2021 at 12:45
There's several options,
You could just carve the notch using chisels.
You could drill the notch using a spade bit and changing the drill angle as the hole grows. you may want to practice the technique on some scrap before you use it in anger.
You could screw a temporary guide block to the joist and drill a hole partially in the joist and partially in the block.
You could drill a series of shallow holes to make a notch.
You could use some combination of the above.
  • Thanks so much for the ideas everyone. I'm going to use some type of drill method, possibly a flexible bit
    – Mike L
    Jul 3, 2021 at 15:35
Notching always compromises strength. Drilling is by far the least compromising option.
