I have a tankless gas hot water heater that powers a shower. There is minimal distance between the heater and the shower.
When taking showers and trying to mix the hot and cold water to get a temperature that's not quite so hot the heater will shut down which creates much colder water. What modifications can we do to allow for a medium temperature?
The heater is turned down to the lowest temperature setting and the lowest flow rate.
