I have two Sonneman LED light strips in my bathroom, each connected to its own transformer. They're controlled by a single dimmer. They have worked fine for 4 years but now when I switch them on they go off and on, off and on, and so on, continuously and simultaneously. Does this suggest a dimmer problem given that it's not one light doing this, but both, simultaneously? Also why would a dimmer go bad after 4 years?
I'll just add that - before this started happening - when the dimmer was turned all the way up, the lights blinkered, so we kept them turned down a notch.
