Can you run a 14/3 to feed two separate zones of lights? Two breakers Two hot legs feeding 2 lighting circuits each with their own switch, and share the neutral?
    See What is a multiwire branch circuit?.
    Jun 23, 2021 at 16:02
  • Two breakers but you have to handle-tie them. But yes, I do exactly that in my shop. Also in many locations they will need GFCI or AFCI, doing that on tied breakers will be complicated, hard and expensive. Jun 23, 2021 at 21:30
  • If I can would I be better of to run 2 14/2’s? Jun 23, 2021 at 23:56
