I've been reading this answer to a question that more or less is my situation. The difference being that I already have a 100A sub-panel (fed by a 50A breaker from the house) in an outbuilding from which I intend to supply the pool circuits.
I believe I am required to run two circuits to the pool area, one for the pump and one for a "convenience outlet". I need 20A for each. So to me, that's two sets of 12awg THHN in a conduit. But it seems like the aforementioned NEC 225.30 is going to further force me to make that a single circuit running out to the pool area with some sort of box out there to split it.
Leaving aside the exceptions available via playing with the configuration...am I getting this right as far as the basic requirement is concerned?
As requested, here's the pump's label: enter image description here
The pump has a short cord with a twist-lock plug.
EDIT: pump will be outside, on a small slab. I intend to run electric underground in conduit up to the area of the pump, and then come up to a post where I'll mount the fixtures. Maybe two if the 6-10' and 10-20' problem doesn't afford me a way to do it all at the same emergence.
  • How deep is the pool 42 inches or less is seasonal and doesn’t require a convenience outlet the pump usually has a 20’ GFCI cord in this case as required by code. Different rules for different pools.
    Jun 22, 2021 at 19:47
  • @EdBeal 54", so it's considered "permanent", at least in Ohio where I live. Jun 22, 2021 at 20:01
  • Yes 42” is the limit for seasonal , article 680 swimming pools, fountains and other installations: (is the code for pools) what type of pump/ filter unit are you using? In some cases a separate convenience receptacle is not required a duplex will suffice, example a 20 amp circuit at least 6’ away but within 20’ with a duplex. We still need the info on the pump if cord and plug connected with double insulation or hardwired I had a similar pool in Dayton and the code has not changed much since then.
    Jun 22, 2021 at 20:51
  • Yes -- is the pool pump permanently mounted, or cord-and-plug connected? Jun 22, 2021 at 23:54
  • @ThreePhaseEel The pump has a twist-lock plug. Jun 23, 2021 at 11:30
