I was recently checking out the plumbing for my dishwasher and noticed an unusual drain setup. The dishwasher drain pipe feeds into a DWV pipe that is open at the top. Is this compliant with plumbing code? I thought the dishwasher drain was supposed to connect directly to a fitting with a high loop, not just feeding to an open pipe?enter image description here
Washing machines discharge the same way.
The standpipe in this case is high and has its own dishwasher P-trap. A clogged sink P-trap will not cause an overflow of sink water through the stand pipe into the cabinet.
The concern is that if the dishwasher empties and its P-trap is clogged, the open pipe will overflow and there will likely be no annunciation (no error code) by the dishwasher because water will flow, just not where intended.
If there is a direct connection, a clogged P-trap will either cause backup into the sink or trigger the backflow / pump error in the dishwasher. But not flood the cabinet and kitchen.
Also, if there is a clog downstream from the kitchen (past both P-traps), the dishwasher discharge will fill the sink before overflowing through the tall standpipe. This arrangement provides some protection.
However, the direct connection often poses a problem of its own. At the connection point of the discharge flex pipe to the drain there is a narrowing often causing fruit pits or seeds to jam the flow.
  • This is probably their version of a vacuum break this keeps the dishwasher from siphoning dirty water out of the drain.
    Jun 15, 2021 at 18:57
  • @EdBeal I was thinking that at first, but when I pulled the pipe out, it was wet. So I think it was in the water of the p- trap. Wouldn't that effectively suck everything out if there was some back siphonage?
    – chizou
    Jun 15, 2021 at 20:54
    Yes @chizou that's my concern too. The flex pipe / hose must terminate well above the trap. However, newer dishwasher models do not require it, as they have a built in trap. Check the manual. But in any case you can cut off the hose and hold it in place with strapping.
    – P2000
    Jun 15, 2021 at 20:58
  • I need to clarify: "The flex pipe / hose must terminate well above the P trap" and then "newer dishwasher models have a built in air gap" (not trap)
    – P2000
    Jun 15, 2021 at 22:08
