I recently purchased a 12,000 btu window air conditioning for a 400 square foot room. The unit works great, until the late afternoon around 4pm, where it struggles to bring down the temperature to a comfortable level. The room has a very large west facing window which gets a lot of solar gain, so I decided to install an outdoor roller shade. This decreased the heat coming off that wall/window significantly, but didn't really help the a/c unit out in the later afternoon at all. I checked the doors and windows, and there doesn't seem to be any gaps where heat could be coming in, what is the culprit here? Should I install another unit to help cool down the room?
12
  • Have you cleaned the filters? West facing with minimal insulation that could be at the max for the unit. The blind should have helped but with the information provided a second unit sounds like it is needed, I would check the filters inside and look at the outside coils if a very dusty area even these can get plugged.
    Jun 15, 2021 at 16:10
    Does the sun beat down on the window unit?
    – JACK
    Jun 15, 2021 at 16:41
  • Where are you? What's the outside temperature in the afternoon? What kind of building is this? What floor is it on? What are the outside walls made of? That's not a tiny room but it's not a tiny A/C. It seems "about right". So various factors could mean you need more.
    – jay613
    Jun 15, 2021 at 17:33
  • @jay613 Southern California coastal town, temperature was low to mid 80's. I live in an older single story house, built in the 40s Jun 15, 2021 at 17:45
    What color is the roof? Is the entire attic inside or outside the insulation envelope? Jun 15, 2021 at 22:06
Get an infrared thermometer.
With this you can measure the temperature of your walls and ceiling, and you will find where the heat seeping into the room is coming from.
I also have a large window facing south, which turned the living room into an oven in summer. I installed a vegetal awning like this:
It makes a huge difference, it looks nice, and the leaves fall off in winter, letting the sun through.
