I am trying to wire a small 12v (ac to dc converter used) composting toilet fan in a room where the closest wiring is a light fixture. The light fixture is switched however, and the fan needs to be always on.
So I will need to re-run wire from the switch so that there is 'always hot' wire to power the fan. Instead of pulling another wire through the wall alongside the existing, I thought I could use the old wire to pull in a new single 3-wire cable (two hots, neutral, and EGC) if this is allowed.
I would then switch one of the hots, while the other hot will feed the fan. In this situation, the neutrals are shared, however I would pigtail the lighting neutral so that it's not linear with the light itself. Is this allowed or advisable?
This is old work, and therefore the wall is not open, hence this work-around. My concern is that the holes in the studs may not easily accommodate pulling two cables through. Either way, I plan to use the existing wire to pull what's needed through, whether it's one 3-wire or two 2-wire; the single 3-wire just seemed like an easier pull.
