We have a 55" OLED TV 55 C9 and its wall bracket go together in the box. However I need to mount it on the wood paneling wall which is 1 cm thick and there is a distance around 2 inches space distance between this wood panel and the concrete wall.
Based on my research on internet the thickness of the wood panel is in range of sufficiency.
But I really don't know what type of screws, stud and how is the right order to mount it? I need an explanation with pictures or video to make sure I understand how to install it correctly and safely because I am not very familiar with the steps.
Below is set of pictures of my setup and items as well as the instruction guide for wall installation.
My biggest concern is since I can access only the front side of the panel then I could not place bolts with nuts to hold back the system and prevent it from pulling out by the heavy weight of the bracket and the TV. They do use screws but it is for the walls with expansion anchor and long, big screws so I guess it can support very heavy weight. What would be the good solution for my setup ? Thank you !
