Upgrading a bathroom fan and I need room to convert a 3" duct to a 4" flapper on the fan (about 7" of length overall). The ductwork is rigid sheet metal and ran directly to the old fan. The duct is above a drywall ceiling that I'd really like to avoid cutting into more if possible.
    Are you trying to shorten the 3" duct in the ceiling by 7"? You might be able to do it with a dremel with a abrasive wheel. An automotive cut off wheel the kind used for exhaust pipes may work too. Post a photo showing how much room you have to work with and you'll get better answers. Jun 9, 2021 at 21:36
  • As a pro I would just stick my plasma cutter inside the pipe and cut it off then put out smokers. A dremel tool with a few cutoff disks may be possible to cut the pipe, or a nibbler tool but that is tight I don’t think my smallest nibbler would fit inside the pipe and cutting in 7” and then trying to cut from inside the pipe with shear metal sheers and in a circle both methods sound like a trip to the ER for stitches. It may be best to take more ceiling down or use a dremel with cutoff disks. I was slow to type and see goose says the same, 3” pipe no cutting from inside possible with sheers
    Jun 9, 2021 at 21:42
  • Where does the duct terminate. Is it possible to shorten the duct on that end and pull the duct towards the termination the appropriate distance?
    – Kris
    Jun 9, 2021 at 22:12
