I have a portable air conditioner, but I don't have a window in my room. I'm only gonna be here for about 2 more weeks, but the temperature is in the 80s/90s, and I'm very sensitive to the heat that it's affecting my sleep, so I'm trying to find a temporary solution. a
There is some sort of vent on the wall with a casing, but it seems I can't remove the casing, otherwise, I think I could simply just remove it, and stick the tube of the portable AC in there, and that should work?
Would it work if I try to vent the hot air out of my room through my door? I would leave the door cracked open slightly (just enough to put the tube through), but I don't know how well this'll work, since hot air will just come in through the crack. I'm not well versed enough with heat transfer analysis to know if the net heat flux coming in is positive or negative with this idea.
Any suggestions would be greatly appreciated!
I'm not too concerned about efficiency as I will only be here temporarily. The room right now is about 85 degrees, if I can get it down to 70-75, I would be happy.
