We recently had LEATHERED granite countertops installed. We are waiting for the majority of the kitchen backsplashes to be cut to height in order to fit under existing wall tile, but one piece was installed already. The silicone is so shiny, it sticks out like a sore thumb. I applied some translucent silicone in one spot to experiment and it is not much duller. I can't imagine latex caulk or grout being an option with this application. I have reached out to our granite company, but I would also like to get other opinions.
  • maxisil.com/…. Not sure if there is a clear matte silicone but some colored option here. You could try wiping the cured caulk with denatured alcohol to perhaps dull it a bit
    – Kris
    Commented Jun 3, 2021 at 12:45
  • @Gunner Yeah, just waterproofing UNDER it and in the tiny corner could be the thing to do in the end. I know a lot of people like this tape method to prevent peeling from rubbing when cleaning.
    – Evil Elf
    Commented Jun 3, 2021 at 13:31
  • +1 Good question for common DIY problem. What is "LEATHERED" ?
    – P2000
    Commented Jun 3, 2021 at 16:50
  • @P2000 Instead of honing the stone to a polished finish, it is smoothed with diamond tipped brushes. It has a slight pebbled matte finish.
    – Evil Elf
    Commented Jun 3, 2021 at 17:51
Wow! Not how I ever installed any backsplash.
I would have applied a small bead of silicone to the bottom edge of the BS, install it on the counter top and push down and hold down until dry (sticks work, weight plates) and scrape off any silicone that squeezed out so all you see is a tiny or no seam. I would not apply it after the splash is installed, it never comes out right.
You can try to remove the excess carefully with a sharp razor blade and slice down between the splash/countertop and silicone very slowly and carefully and remove the excess unsightly silicone.
Tape never works, there will still be a raised edge that you will have to smooth out.
  • I think this answer provides the best approach, since you say in the question most of the backsplash hasn't been installed yet. So I won't make this an Answer but if it HAD been installed I would say use a much smaller bead and use color-matched caulk, maybe black, rather than clear. IDK if black is available matte but I'm pretty sure clear isn't.
    – jay613
    Commented Jun 3, 2021 at 16:49
  • And ya as you say in the question don't use grout there, it won't last. You need a tiny bit of flex between the counter and the backsplash.
    – jay613
    Commented Jun 3, 2021 at 16:55
    In the end, the company's seasoned installer stated that with leathered granite, even a tiny seam crack filled with silicone will be shiny. He is going to have the crew just seal the bottom of the backsplash to the top of the countertop and leave the seam empty. That is how he does them and a newer hire was just doing the best he could.
    – Evil Elf
    Commented Jun 3, 2021 at 19:23
Based on the super straight lines I assume the installer used the tape method but chose to expose a lot of granite rather than targeting just the seam.
Either have them do this or do it yourself after they install everything:
Courtesy of https://www.tilecleaning.org/recaulk-granite-countertop.htm
For the existing install the only fix is to remove the silicone and apply it properly.
    I have never had any luck with the longevity of "Siliconized" products. I want to stick to a 100% silicone solution.
    – Evil Elf
    Commented Jun 3, 2021 at 13:32
  • @EvilElf I guess it comes down to the physical procedure then. The installer could have used tape as seen here: pinterest.com/natco465/re-caulking-granite-countertop or youtube.com/watch?v=SxtkcK1jzdg
    – MonkeyZeus
    Commented Jun 3, 2021 at 13:39
  • They DID, but apparently their routine is a large swath of it? In the end, I imagine I will tell them to install them and I will seal them myself.
    – Evil Elf
    Commented Jun 3, 2021 at 13:43
  • 4
    @EvilElf Sounds like we have an answer then; if you want it done right then do it yourself!
    – MonkeyZeus
    Commented Jun 3, 2021 at 13:46
In addition to the preferred option of only caulking in the crack not on the crack, there's also the option of using colour matched and texture matched caulking.
It's usually used for caulking between grouted tiles and a finishing edge or counter top, but it could also be used where there is an existing gap that needs filling by anything but shiny silicone.
They are far more expensive than regular caulk, but you only apply it to the critical interfaces. It's acrylic based with the endurance of silicone and is anti-mold.
With a wide variety of colours available you can match it to the dominant colour in the granite.
I don't know all the brands, but here's an example that I have used: "Keracaulk S" Sanded Acrylic Caulk 311ml - Ivory
    I am currently looking at Poly-Sil by Color Rite. They seem to have a great following in contractor forums.
    – Evil Elf
    Commented Jun 3, 2021 at 17:52
