So it looks like part of my house had the door trim installed after the carpet. I'm currently in the process of ripping the carpet up and installing vinyl plank flooring, and noticed the huge gaps. Are my only options replacing all of the trim or caulking the bottom? Are there other options/products available?
I also noticed gaps in this corner of drywall, as well as the drywall sheets touching the slab. I assume the only reason you don't do this is so that moisture isn't wicked up (given the gypsum does look soft). I figure I can throw some drywall tape on it and mud it up.
Lastly, how do you account for the flooring around a curved fireplace? Is there a way to flush-cut the bottom of the brick, or do you install quarter-round trim at slight angles?
I also assume all of the minor holes/gaps from tearing out the tack-board won't be an issue.
