-1
I’m trying to drill a hole into the concrete ceiling in my apartment to first insert a hook, then hang the lamp through. The lamp is a plug-in btw.
Just wondering what are the necessary tools and precautions I should consider?! The lamp is 20lbs, Should I be worried that the ceiling will break?! Where should I drill (if that even matters for a 20lbs weight)? What hooks should I use? Etc., etc.
Thank you so much for helping!!!
  • are you allowed to drill into the ceiling in your apartment?
    – jsotola
    Oct 27, 2021 at 16:07
You're going to need a hammer action drill, masonry drill bit, and a masonry anchor bolts hook (search for expansion hook and concrete or ask at a hardware store). 20lb isn't that much but given it's going to be overhead I'd probably over do the connection.
It's going to be a pig to drill upwards into concrete but if you have a good drill and new drill bit it's doable.
You probably want glasses and a mask as drilling into the ceiling is going to create a lot of dust that will fall onto you.
  • Part of the question involves hardware. You might mention what you're recommending.
    May 30, 2021 at 14:09
    I've used lag shields and lag hooks for similar projects. Get an old clear Tupperware cover or cut a tennis ball in half and drill a hole in the center. Place the cover or half ball over the starter hole and continue to drill, letting the cover or ball catch the dust.
    – JACK
    May 30, 2021 at 16:25
  • Or have a helper with a vacuum get the dust as you drill. May 30, 2021 at 17:54
    @JACK that's a great idea! I'll have to keep that in mind.
    Oct 27, 2021 at 16:04
    @FreeMan I cut a basketball in half for when using a 5 or 6" hole saw for recessed lights... Glad you like it.
    – JACK
    Oct 27, 2021 at 16:23
