Adding a ceiling fan in a room where nothing existed before. I have a single pole switch on the wall that controls an outlet. When I opened the switch, it looked like it was an end-line or switch loop switch (are they the same thing?). Only a single 14/2 wire coming in with both black and white connected to switch.
Would it be possible to tap into this as a power source for the ceiling fan addition? I don't care if the ceiling fan is always live and controlled from the pull chains. Or controlled from the single pole switch along with the outlet it already controls.
