Is it OK to forego installing a vapor barrier beneath a concrete slab (garden shed foundation) under the following set of circumstances?
there will never be any flooring material placed on the slab and the only concern is the possibility of moisture damage to the sill over time because the soil is frequently sodden and very slow to dry after a heavy rain
an EPDM sill gasket will be installed under "MCA" pressure-treated sill plate lumber
