I just replaced the entire shut off valve for my toilet and its still leaking. I used all new parts. Would could be the issue?
1Probably one or more of the connections are leaking. Find where leak is coming from, and either try to tighten connection or disassemble and use tape or pipe paste to seal connections.– crip659May 27, 2021 at 0:17
1Pics or it didn't happen - or in other words, show us what you're seeing because there are many things which could have gone wrong.– brhansMay 27, 2021 at 2:02
1leaking how/where?– Jimmy Fix-itMay 27, 2021 at 2:57
1I am going to try the tape and see if that fixes the issue. I think it will as I found a video that shows that needs to be done ant its exactly on the spot that is leaking. Thank you for the replies. very helpful!– user135621May 27, 2021 at 12:58
Add a comment
