I am trying to install a new access ladder to our attic, cutting a new hole etc. There's only one room in our 1038sq house (built in 1952) that will work, and after taking a closer look there is a water pipe that would interfere with the opening, were I to cut a new hole in that location, which would run parallel to the joists.
So it seems like my only other option is to cut a new hole and install the access ladder perpendicular to the joists, which means cutting probably 3 of the joists which are roughly 30-35ft long.
Based on most of the info I've found, you should ideally install the ladder parallel to the joists, only cutting one. But if I frame out the access correctly, is it a problem to install it perpendicular to the joists? The question is, how can I frame it correctly? I've only found this way of doing it:
Which would seem to entail adding two add new, in my case, 30-35ft joists to support the new cut. Is this correct, necessary and is there a better way to do it??
