I have a 5 years-old Whirlpool WDT910SSYM3 dishwasher and very recently it stopped draining at the end of the washing cycle.
Every time I tried to make it drain, it emits a weird and unusual crackling sound (see attached video).
I suspect the drain pump might be damaged (I already removed it and checked everything for obstruction and I could find nothing - well... everything but the evacuation pipe, although the weird sound makes me think the pipe is not the problem).
Before I try and find a replacement drain pump, could anyone with previous experience in this let me know if I'm on the right track?
Thank you,
  • Have you tried hooking up the pump to an external power source to check for motor operation, good bearing, etc.?
    – JACK
    May 21, 2021 at 20:15
  • @JACK I don't have anything to actually test that: it's AC current and a very specific connector, and I would not feel comfortable toying with it.
    – ereOn
    May 21, 2021 at 20:27
    Your brains are showing. Good for you for staying in your comfort zone.+1
    – JACK
    May 21, 2021 at 21:41
  • Does it drain after the initial rinse cycle?
    – rogerdpack
    May 21, 2021 at 22:24
  • @rogerdpack I'm actually reluctant to start a complete cycle, since last time I had to drain it manually (and it was painful and quite frankly, disgusting). I however triggered the "drain" function on the dishwasher, and it emits that weird sound still. I ordered a new pump and set-it up but sadly, the weird noise remains... I'm starting to think something is obstructing the evacuation pipe after all....
    – ereOn
    May 27, 2021 at 0:03
