I have an industrial exhaust fan venting heat from the top of a stairwell. It is a CentriMaster ModelPRN PRN110 with specification sheet here: http://www.acmefan.com/InformationFiles/ModelInformation/OLDLiterature/ModelPRN.PDF
I'm installing a vent at the bottom of the stairs for make-up air, and have a question about the duct size.
From the 'dimension data' (p. 6), the fan ceiling cut is 16 x 16" (A), but it says "Duct size 10". Does this mean I should use a 10" duct for the make-up air, or a 16 x 16" square?
From the 'performance data' (p. 5), the PRN110 has RPMs 2477 through 4464 with CFM 600 through 1090 at .000", or CFM 578 at 1.000".
- What are the
inch
rows in that table (i.e. .000", .125", etc.)? - How do I determine the RPM (what row of the table do I read)?
- How do I determine the CFM (what column of the table do I read)?
- Once I know the CFM when the fan is on, how do I know what size passive duct to install for the make-up air? It seems like just using an equal size duct (10" or 16x16") should be sufficient.
- What are the
I'll be using an electric-open default-close damper tied to the same 120V thermostat that drives this fan.
